Manuals or help removing the main shaft from a Diehl# 2 turret lathe,
Results 1 to 1 of 1
    Dec 2017
    Michigan
    Default Manuals or help removing the main shaft from a Diehl# 2 turret lathe,
    Help!
    My customer has been using a Diehl #2 turret lathe with a bar feed for the last 55 years, still runs, but need to replace the main drive belt. I know this was built during WW2 and Dieh mainly made wood working equipment. I can not find any manuals or pictures on how to remove the main drive shaft from the frame. There is a gear that appears to be pressed on the left side, and some kind of lock collect on the right side. The pulley is in the middle.
    If anyone can help with a manual or first hand knowledge, or just some sketches I would be very greatful. The company is of the attitude "if it works, keep using it".
    Thank, you..
    Bob Cue
    Hi-Q Services
