Ales Honsa
- Feb 1, 2016
Hello,
I recently purchased a German surface grinder manufactured by ABA. Unfortunately there is no any label with type identification. There is only logo ABA on the bottom and label ABAwerk on the top of column. Grinder parameters are following:
- Table size about 500x200 mm with 3 small sized T-slots.
- X table travel is about 470mm. There is no wheel for manual feed, only hydraulic feed is available. Hydraulic cylinder has only one side piston rod (this wondered me - grinders has usually cylinder with rod on both sides).
- Y table travel is about 205 or 210mm. Feed is done manually by wheel operating trapezoidal screw and there is also automatic feed done by crank mechanism with ratchet wheel. Crank mechanism is probably rotated hydraulically (recently I don’t look inside).
- Z grinding headstock travel I estimate about 300 or 350 mm. Feed id only manual by wheel (there is not motorized lift), one wheel rotation is 1mm travel.
In attachment are few photos of the grinder.
Does anybody know type specification of this grinder, please? I’m also looking for handbook and I will also need some spare parts (for example ratchet wheel of automatic feed is missing).
