How are American engine mfgs able to make high HP with simple designs? - Page 4
Page 4 of 4 FirstFirst ... 234
Results 61 to 74 of 74
  1. #61
    May 2017
    FINLAND
    1,129
    298
    532
    Quote Originally Posted by goldenfab View Post
    Everything I have heard from old timer mechanics is the fuel of today is terrible in comparison with the past.
    Only good thing nowadays is E85 or 85% ethanol. Pretty common pump gas here in Europe.
    Equivalent to about 112 american octane and not sensitive for advance.
    In a modern 4-valve combustion chamber 15:1 or 16:1 is probably ok compression ratio.
    Or 60psi boost at 7:1 compression
  2. #62
    May 2002
    South Central PA
    12,664
    1661
    2823
    Quote Originally Posted by CalG View Post
    No need to wonder.
    OHC, Valve in head and L heads were popular all around the same time, but I suppose one could make a case for a progression.
    "If you want to lean something new, read an old book."
    My impression is that everything was tried all at the same time. Pre WWI cars have an unbelievable range of innovative designs from the simplest to the incredibly complex. Here's a 1912 Peugeot 7.6 litre DOHC 4 valve that beat engines twice it's size and won Indy in 1913. Some of the earliest IC engines were OHVs, it seems to me that flathead engines were an effort to simplify things, not the starting point.
  3. Likes Bobw liked this post
  4. #63
    Jan 2007
    Flushing/Flint, Michigan
    6,324
    259
    5148
    Quote Originally Posted by 72bwhite View Post
    wasn't the some law that every town had to have a Telegraph and or Telephone road
    Perhaps, but Telegraph in Detroit was the "unofficial" testing and proving grounds for just about every 60s and 70s American muscle car.
    Certainly not officially sanctioned by the car companies but a lot of testing against the competition occurred at nights on this road which would result in tweaking things back at the factory before a car or powertrain went into full production.
    A different era.
    One word describes why you can make so much more power now......Computers.
    Look at a old fuel injection setup and a new one, look at ignition curves now and an old mechanical distributor.....computer control.
    Then there is the computer simulation and trial of many designs which earlier meant building one, testing, guessing, building again.
    Bob
  5. #64
    Jun 2006
    Near Seattle
    4,380
    2422
    1084
    Some supporting facts from owning one LeMans engine program, and then getting smart and leasing engines from others, with a side note from small airplanes...
    LeMans cars...
    1. They all had impressive power-to-weight given the rules, air intake restrictions, spec fuel, etc. And in the much-lighter-than-any-street cars they were run in, they'd smoke most muscle cars. Remember, we raced against track versions of Ferraris, Porsches, GT40s. The acceleration differences could be stunning.
    2. They all required very elaborate warmups early in the day. Think a heater and pump running pre-warmed coolant through the engine for 30 minutes before it was started the first time. Yes, by the rules, the driver starts the car, by him/her self, sitting a the wheel. But that's not how it works for the warmup you don't see before the car comes out of the garage before the race. (This can't apply to say the World of the Outlaws, where they do engine changes on very short notice.... Wonder how that works... Same for drag racing?)
    3. Even LeMans engines aren't normally built to last 24 hours - those are special builds....
    I'm sure F1 is pretty similar, if not more extreme.
    As for small plane engines - well various regulatory and liability issues have caused their development to be kind of stuck, but their biggest claim to fame is very high reliability in a high consequence environment, at 80% power all the time, with 100% used for real on purpose every flight (that whole taking off bit...)
    If you had to drive your street car at 100% throttle for the first 5 minutes of every trip, followed by 80% for the rest of the trip, your street car engine would need lots more attention too.
  6. #65
    Jun 2016
    CANADA
    Manitoba
    243
    49
    96
    Quote Originally Posted by bryan_machine View Post
    Thats exactly why they go over an aircraft engine so meticulously before every flight.
    As to the higher compression ratios I alluded to previously, it is why the power numbers are higher in todays car engines. Those higjer compression ratios are only possible because of computer controlled fuel , valve timing , aluminum heads and ignition. Together they adjust fuel air and timing so it can take advantage of the higher ratio. Without the computer , good luck.
    With direct fuel injection they can literally wait until the piston is just past tdc to prevent pre ignition, before charging the cylinder with fuel. Meaning 15 to 1 or more CR is no problem.
    Just my two cents worth.
  7. #66
    Jun 2011
    New Jersey
    651
    335
    238
    Quote Originally Posted by Spud View Post
    Something I have been curious about: How can the likes of GM, Dodge make high HP engines utilizing simple technology (relative to the Euros and Japanese) ? When the Euros make high HP engines, they are complex , like the BMW in the McLaren F1 of the 90s, Ferrari engines, Mercedes engines in their high-end models and the Pagani, the W16 of the Bugatti.
    Look a the Dodge Demon, that thing makes 840hp (don't know if that is measured at the wheel or crank).
    American engines just seem soo much simpler than European high HP ones, is that an erroneous perception ?
    While a four cam Aston Martin V8 or Jag V12 is a marvel of design, a simple Ford, Chev, or Mopar V8 can do wonders. It was Ford's GT-40 that finally conquered Ferrari's V12 at LeMans, with a 7 liter "FE" big block V8. They did it again in 2016 with the V6. "Anyone can make it complicated, it takes a genius to make it simple." Not my words, but you get the idea.
  8. #67
    Jun 2012
    Michigan
    8,564
    2551
    2912
    Quote Originally Posted by SeaMoss View Post
    Valves shmalves. Cams, heads, rockers, rollers, followers, pushrods, who needs all that junk. Here's 2400 hp and it lasts longer than ten seconds
    That is cool..and I thought I invented that engine ..even built a prototype. but ran out of time and never built the running model ..yes in gas .. sure would like to find all the specs on this engine..
    Fairbanks Morse Engine Opposed Piston Technology - YouTube
    Junker another cool engine Jumo 25 D Engine for airplanes - YouTube
  9. #68
    Mar 2009
    Northern CA, USA
    60
    65
    I once worked for Fairbanks Morse, but not the FME unit.... These engines are still used in small ships and tugs, including many US Navy Ships. The opposed piston design is still used for dual fuel applications, and has a 40,000 hour design life. Thaddeus and Charles would be proud....
  10. #69
    Apr 2004
    Modesto, CA USA
    5,698
    841
    p4.jpg[/QUOTE]
    What is the extra gear near the bottom towards the person. I it a oil/water pump or something else.
    Bill
  11. #70
    Oct 2005
    9,848
    16997
    5072
    Quote Originally Posted by Rigor View Post
    They doo ?
    Whats wrong with "Kick tire, Light fire, Push go button" ?
  12. #71
    Oct 2005
    9,848
    16997
    5072
    Naw....I like 3 sided engines....
    Napier Deltic - Wikipedia
  13. #72
    Mar 2011
    Denver, CO USA
    11,159
    41
    4960
    There is nothing particularly simple about American engines.
    The likes of the Italians and Germans add parts but that's not where the complication is.
    The complicated part is the FEA modeling, testing and iteration.
    Then the real key...the engine management systems.
    Modern closed loop controls allow an angina to perform across a multidimensional regime, adapt to different fuels, and even learn the driving style of the operator.
    That alone is a huge boon.
    Now ad in variable valve timing, direct injection, and a few other enabling technologies and you have a modern engine.
    Even an old vortex v6 pushrod motor can be an excellent, powerful, efficient motor.
    The main reason for over head cams remains the ability to rev safely.
    Like I said, once the heads and combustion chambers flow, all the rest is just enabling technology for the engine management.
  14. #73
    Mar 2011
    Denver, CO USA
    11,159
    41
    4960
    Learn something new every day...thnx
  15. #74
    Mar 2017
    CHINA
    1,813
    1127
    How about something simple, like an H-16 ?
