Results 1 to 10 of 10
Like Tree2Likes
  • 2 Post By Matt@RFR
Thread: I need some dies made - Hobbyist preferred
    Noel.C is offline Plastic
    May 2012
    Belfast, Northern Ireland
    Default I need some dies made - Hobbyist preferred
    Hello
    I am trying to get a set of dies made that will enable me to widen the
    scope of my hobby from medieval chainmail craft into scalemail craft.
    I am not an engineer, but I know what I am looking for and I have put
    together a drawing.
    or see this link
    http://a3.sphotos.ak.fbcdn.net/hphot...96386779_n.jpg
    The dies are meant for use in a 1/2 tonne arbour press
    The material to be processed will be a 1mm mid to hard temper Aluminium
    I will leave tolerances up to the individual who takes on the job.
    Exact measurements I will also leave up to the individual who takes on the job. Just
    so long as the end result is roughly as expected.
    The cutting edges on the punching and stamping dies should be tempered
    and concave to optimize the force requirement as much as possible.
    It would be great if a hobby die maker came forward for this because
    as a hobbyist myself, we can appreciate each other and our goals. I
    do not wish to have my scalemail design mast produced in a factory, I
    want the joy of making them myself.
    Trying to get these dies made has been a terribly painfull experience for
    me, and that might be due to my own lack of engineering knowledge, making
    it difficult for me to get the job done by a factory.
    A quote for this would be really great
    Noel Craig
    May 2012
    If it would be of any use, I could provide a DXF of the
    cutting part of the male and female cutting die. As this is the
    only part with a complicated shape.
    http://a5.sphotos.ak.fbcdn.net/hphot...42363150_n.jpg
    Also
    Just because I have styled the concave in a certain way, it
    really doesnt matter how it is styled, just so long as it gets
    the job done I guess.
    TDegenhart is offline Stainless
    Mar 2011
    Geneva Illinois USA
    1,462
    I am confused by what I see. In post 1 I see a set of dies to make an oval with two holes. In post 2 I see what looks like a horse collar. No indication of quantity. Are there multiple parts or one? Do you expect to run these parts yourself in a 1/2 ton hand press? What about cost per part and die cost? If the oval part is what you want, I would suggest a small progressive die with hand feed.
    Tom
    May 2012
    Quote Originally Posted by TDegenhart View Post
    Tom
    I would like to know how much it will cost me to get one set of each die.
    I would describe it more of a teardrop more so than an oval but ok.
    The end result should be a single tear drop part with 2 holes and a slight bend
    I expect to make them one by one on my arbor press
    To get the parts manufactured for me, it would cost around 90 pence for
    teardrop, which is no good to me, I might need thousands and I dont want
    them mass produced for me, I want to do it myself one by one, at my own
    pace in my own spare time.
    The second image just illustrates the cutting die with a concave type
    shape to the blade, I posted it to simply illustrate that I am capable of
    doing it in 3d, if it needs to be done in 3d, but I would rather not.
    Hope that clears up any confusion
    Matt@RFR is offline Hot Rolled
    May 2004
    Paradise, Ca
    953
    I have no dog in this fight, but what you need to do is make a print of the PART that you want to produce and let the die experts design and make the die set for you. Suggest nothing about how the tooling should be made or designed. Leave that up to the experts, and you're going to be a LOT happier with how this all works. It sounds like you're hovering over the process, and at best, that's annoying. At worst, it will make people not want to work with you at all. I just fired a customer for roughly the same thing.
    digger doug and thermite like this.
    May 2012
    Quote Originally Posted by Matt@RFR View Post
    Thank you for that no-bull response and I wish I could have had it a few weeks
    ago, least that way I would have had less headaches :-)
    Ok
    I want dies to create this part
    http://a2.sphotos.ak.fbcdn.net/hphot...13560393_n.jpg
    Dies will work in Arbor Press
    1mm Aluminium will be used
    Is that more appropriate? because that was a dam sight easier for me lol
    Jackshop is offline Banned
    Sep 2012
    Redwood City California
    8
    Default Quotes
    I can make those dies, I am a machine shop and Model airplane hobby shop as well.
    Jack Anton
    easymail66@yahoo.com
    7 machines total
    3 cnc machines, Lathe and mill.
    Surface grinder - automatic.
    please email me.
    thank you
    Jack
    Quote Originally Posted by Noel.C View Post
    Hello
    together a drawing.
    Click image for larger version.
    or see this link
    Noel Craig
    ewlsey is offline Stainless
    Jul 2009
    Peoria, IL
    1,898
    Quote Originally Posted by Jackshop View Post
    Jack Anton
    7 machines total
    please email me.
    thank you
    Jack
    Most RFQs are awarded in a few days from the first post. Please stop dredging up these long dead threads.
    You're off to a bad start here.
    kpotter's Avatar
    kpotter is offline Titanium
    Apr 2001
    tucson arizona usa
    3,494
    I make a die just like that I sell them on my website they are 22 dollars they are used by the people like yourself who make chain mail. Check it out Potter USA .com they are called pancake dies they are much cheaper than a traditional die but work well for what you are doing.
    Little T is offline Plastic
    Sep 2012
    Somewhere, USA
    9
    Quote Originally Posted by ewlsey View Post
    Yes. Please check the date of first thread. But, at least it isn't years old like I have seen before
