cinematechnic
Cast Iron
- Apr 11, 2005
- Walnut Creek, CA
I am posting to see if there are any shops that have a waterjet and are willing to run small small jobs from simple CAD files (one-off or lots less than 10) for my small opto-mechanical prototyping shop.
I'd prefer to work with someone in Southern California that I can personally visit, but that's not a deal-breaker.
I'd like to find a shop that I can keep sending work to. I can be very flexible in terms of letting you work my little job in to the available space between your bigger jobs. Also I will pay COD on completion of work.
My parts will mostly be aluminum (6061 or MIC-6)thickness 1" or under, or thin sections (usually 1/8" range) of low carbon steel or austenitic stainless. Designs will usually be fairly simple.
My parts will be small (under 4x4") except for the occasional aluminum fixture or bracket that may be a bit larger (usually 12" or under max dimension).
Thank you for taking the time to read this. If you are interested in working with me, please respond via PM and I will get back to you promptly.
