CaliEng
- Aug 17, 2013
- california, usa
Hi guys,
I am located in SF bay area and need a CNC machine shop to machine some aluminum parts for a project. I would not mind travelling out from the bay area as long as you are about 1-1.5 hrs away.
I can provide a drawing if you are able to.
The parts consist of a precise cut aluminum ring cut to a outside diameter of 24" and have holes for captive screws and dowel pins put in the side of the ring.
Corresponding aluminum blocks with matched threaded holes for the captive screw and dowel pins will have to be machined to fit each location on the ring. There are 14 aluminum blocks that screw on the ring.
I tried uploading a picture but it would not let me.
Roy
Roy
