machining of large aluminum sheets
Results 1 to 2 of 2
    Jun 2006
    PA
    541
    11
    27
    Default machining of large aluminum sheets
    I have several dozen large aluminum sheets that need to be drilled and countersunk for a #10 screw. The largest sheets are 144" long x 54" wide and have several dozen #10 holes. They are 1/4" thick 6061-T6.
    We have had these machined at a local shop that has a large cnc router with a vacuum table and that worked well, but they are swamped with work right now and lead times are long.
    We are located in Clearfield Pa, so I would like to find someone in PA, OH, MD, VA, NY or NJ. We have trucks running to NJ and NY on a weekly basis, so pickup and delivery would be easy to those areas.
    Please PM me if you have any leads for shops that would have this capability.
    thank you
    btm
    Sep 2008
    Florida
    280
    24
    68
    Sounds like maybe punch press work to me (there are countersink punches). Is there a vendor you know of that has a punch press?
