Need machining work done, small lot, must take SOLIDWORKS files
Results 1 to 17 of 17
    Aug 2004
    NY, USA
    289
    Default Need machining work done, small lot, must take SOLIDWORKS files
    I'm wondering where the best place is online to submit Solidworks part files to get quotes from various machine shops around the country to make parts for me. I do small lot stuff, usually only 1-5 pieces of any part I make.
    Jun 2003
    Mebane North Carolina USA
    6,202
    51
    1659
    Around the country?
    In other words scour the earth for the cheapest price?
    Oct 2005
    erie,pa
    8,835
    15867
    4473
    And I might add to mebfab's post...
    Direct transfer of solid model files to manufacturing is
    really good and needed on complex curvy surfaces like
    plastic bottle molds.
    But if needing a simple machined lathe part for instance,
    a print will get you many more response's.
    As well as get you to properly tolerance your requirements
    for the parts.
    May 2004
    Paradise, Ca
    2,001
    557
    944
    Looking only for shops using SolidWorks is silly. SW will export numerous file types that will work with a huge variety of other software just fine. Also, If I'm using '08 SW (which I am), and you're on '09 or '10, then it's a mute point because you're going to have to send another file type anyway.
    Now that I've offended you, please send your files to me for a quote.
    matt_rfr(at)sbcglobal.net
    Aug 2004
    NY, USA
    289
    every machinist I have worked with likes drawings to be dimensioned a certain way by their preference... so having the solid model takes all those problems away.. ontop of the fact that it's impossible to miss a dimension sending a solid model... there are many solidworks facilities out there.. so I'm sure I will have no problems..
    thanks for your help.
    Feb 2008
    Brisbane Australia
    1,048
    28
    88
    Quote Originally Posted by squale View Post
    The problem with solidworks models only is that the dimensions are not toleranced, my customers usually supply a model and a drawing with applicable tolerances.
    Aug 2006
    Munith, Michigan
    2,079
    177
    451
    Squale,
    It may be easier for you to do it this way, but please realize that this severely limits your choice of machine shops. There are a lot of very good places out there that may not be able to afford that program.
    Right now, I receive prints in CAD, jpg's and dwg's and even the occasional faxed print, but have NEVER had a customer suggest Solidworks.
    Frank
    www.randolphmach.com
    Aug 2007
    Canada
    19
    Instead of giving the whole country a crack at it why not go out for quotes within a one hour drive of your location, unless you live so deep in the woods you have to come out to hunt.This will help keep shipping costs in check as well as the phone bill.
    Sep 2007
    Washington
    4,513
    85
    1025
    Uh, no, not really. If I get something that doesn't have a tolerance I go back and ask what it is. I need to know if it's OK to be under and/or over, and by how much. There are "blanket" specs that give normal tolerances based on magnitude, but generally there's something that needs to be held tight. If it were really up to me, I'd go +/-.1" all over and be done with it . Wouldn't get many repeats though.
    I also get specs in all sorts of formats, from pen-n-paper to AutoCAD, but never SolidWorks.
    Regards.
    Finegrain
    Oct 2005
    erie,pa
    8,835
    15867
    4473
    So sorry, I do not dimension soley to what the shop want's.
    Dimensioning will be done such that the finished part fit's it's mating parts.
    A shaft, for instance, with severall diameters.
    The lengths of each dia. may not be dimensioned off the last one
    (incrementally) nor may they all be dimensioned absolutely off of one
    end either.
    Some may be dimensioned off of a shoulder, the bearing fit's for example
    on an electric motor shaft. The other dimension's come off of these,
    the stack up errors end up in the center where the punchings get
    presssed to.
    Now I could throw in a general tight tolerance for everything, but
    the bearing fit's are in tenth's, and I really don't need (or want to
    pay for) the overall length to be held to a tenth as well.
    When I get a call from a vendor asking me "what do we have
    to hold, what can we let slide ?" I know they don't
    know how to read a drawing, only look at a cad file.
  11. #11
    Aug 2007
    Union Grove, WI
    37
    Hello,
    We don't seem to have a problem with your requirements.
    Feel free to contact me, we can discuss your projects.
    [email protected]
  12. #12
    Jan 2010
    Shenzhen city, Guangdong province, China
    Hello,
    We would like to help do this, please contact me freely at [email protected]
    Susie
    www.dancul.com
  13. #13
    Nov 2005
    Maryland
    8,502
    741
    1055
    And I'm wondering where you're located.
    Forum policy requires a location in your profile. Please add it.
    - Leigh
  14. #14
    Jan 2010
    North East Ohio, USA
    Quote Originally Posted by The real Leigh View Post
    - Leigh
    Good catch. Guess they're gone now.
  15. #15
    Nov 2009
    Michigan USA
    1,023
    75
    202
    Hello, we do not have solid works but can except .dxf files and would welcome the chance to quote.
    Please PM me or send correspodance to [email protected]
    Thank You
  16. #16
    May 2005
    CT
    742
    We can read any file you can send, BUT will NOT quote anything without a dimensioned print. This applies to Boeing, Lycoming and everyone else including you. There has been too many huge mistakes caused by solid models over the years. Hope you can understand why from our side of the fence.
  17. #17
    Feb 2007
    India
    146
    17
    Wink
    If India is OK for you, then please send it to me at [email protected].
    file can be in any format, any type.
    regards
    Pali
