drcalculator
- Apr 19, 2017
Hello,
I'm looking for a quote for a single part cut from AR500 (customer supplied material). It is a 7.5" diameter disc used for a small combat robot. A picture is attached, PM for cad files.
It will be cut from 3/16" AR500 which I will mail to you.
In the center going to be a bearing pressed in, mcmaster-carr# 57155K338 so it needs to be a straight and fairly precise cut. If needed I can ship the bearing too. Alternatively, if tolerance is a concern the hole for the bearing can be slightly undersized and brought to size with a reamer.
Thanks!
Thanks!
