Need Small Steel Plate Machined With Good Cosmetic Finish
ljgoldberg
Aug 26, 2004
Rutherford, NJ
We need 200 pieces out of .120" - .125" mild steel, overall about 2.25 x 1.75.
Finish with fine bead blast and satin nickel plating.
The finished parts must be wrapped in paper for shipping to avoid marring the finish.
Please respond directly to ljgoldberg at geemale.
Delivery within a few weeks required.
Larry
Clarification
Drawing shows 2.28", text specifies 2.25".
Same tolerance on the 1.75"(text dimension)? That dimension is not noted at all on the drawing.
Drawing and dimensions are exact and correct. Message was to ballpark the item; not micro-machining, not shipbuilding.
0.98 + 0.78 = 1.76. Small typo in the description, but the drawing is correct.
Sorry for any confusion I may have created.
Larry
Just for future reference, I always give the "overalls" a wee bit more than
the actual.
The overalls are for both your quick estimating (of capable machine size)
as well as material ordering, so it's always better (and less cornfusing in
this example) of over sizing.
Thanks for the tip on "overalls".
I've gotten one quote so far, anyone else interested in what should be an easy part?
Don't be put too far off with the cosmetics, just don't drop them after machining, or throw them all into a tote after bead blasting. Wrapping in newspaper after plating will do just fine.
The item can be seen in use here;
CV3-1-Beta Industries, the source for quality control products | Beta Screen Corporation
Larry
RFQ Closed
The part is now sourced locally for $6.25, material and labor, excluding bead blast and plating.
Larry
Larry
Laser out of 11 ga P&O, tumble, clamp in soft jaws and finish the hole.
Nothing but gravy there if you have the laser.
