clarnibass
- Dec 23, 2015
Hi
I'm looking for someone who can make a specific reversed chamfer tool. Preferably HSS, but any type of tool steel (hardened) might be ok. I'm open to any suggestions from whoever makes it about the material or the tool. The tool will be used after a drilled or reamed hole.
I'm attaching a rough sketch of the tool, a sketch and photo of the result of using the tool and a tool that is a little similar, just without the angle (countersink tool).
At least six flutes/teeth, preferably more (exact number of teeth doesn't really matter).
Chamfer angle 20 degrees or 140 degrees as marked in sketch.
The example of the countersink tool shows a small 20 degrees relief angle, a shallower angle (about 45 degrees) for the rest and then a very small relief. Some or all of this may be unnecessary.
The top is 3/8" as it will be held by a 3/8" end mill holder or ER collet.
For the outside diameter at the cutting end, the first one I need is likely 10.80mm and I will probably need several at different diameters (between 8mm and 20mm). I'm still checking exact diameters.
Through hole or threaded hole is not determined yet, likely threaded for part of its length.
Some of the details might depend on price difference of different features.
I'm in Israel but I can pay with PayPal and I have an address in the USA to shop to if absolutely necessary.
Email [email protected]
Thank you!
Thank you!
