Blazini
- Apr 2, 2014
- Easton, PA
Need a gear made for a '40s sheldon lathe. Original gear looks to be cast and since it seems to be the gear thats always taken the hit from a crash I'm thinking the replacement should be brass.
Gear has 50 teeth,
an OD of 3.233"
Plain bore .628"
16 DP
Should be 14.5 PA
Has a back hub spacing of about 1" but this isnt necessary, I can make a spacer
Basically just looking for a disk with some teeth on it.
Gear has 50 teeth,
an OD of 3.233"
Plain bore .628"
16 DP
Should be 14.5 PA
