rbertalotto
- Dec 6, 2008
- Dartmouth, MA
I need the attached aluminum bushings produced. Initial order will be for 100. Future regular orders will follow roughly every 3-6 months.
Only critical dimension is outside diameter and inside bore. Length, countersink and edge chamfer are non critical.
Outside finish needs to be fine turned or polished with Scotch Brite pad. Needs to look clean and professional.
I have been making these from stock 5/8" rod that is delivered at .635 +/-. I simply polish with Scotch Brite pad in the lathe and then cut, drill, end finish as shown.......Simple! But a real nice job for a small CNC machine.
Sorry for the crappy drawing....email me or call for more info
[email protected]
508-525-0367
Roy Bertalotto
Roy
[email protected]
508-525-0367
Roy Bertalotto
Roy
