Hello I have the following 3 manifold parts that i'm looking to have produced. Need 5 sets made, each set has the following
6 bottom covers. The 16 bores are to be M5 tapped.
Manifold - Bottom Cover v42.step - Google Drive
3 right bodies and 3 left bodies. The three threads on the front are 3/4-16 threads for compression nut to screw onto. It was taken from this adapter model here.
Manifold - Left v42.step - Google Drive
Manifold - Right v42.step - Google Drive
6 Riser bodies.
Manifold - Riser Output v42.step - Google Drive
Parts were designed in fusion 360 as source. Standard tolerance and no special surface finish required.
6 Riser bodies.
