Hi All,
I'm looking for a vendor that can cylindrically grind a few welded assemblies. The assemblies are essentially a stainless tube mounted on a shaft, with the shaft being removable if needed. The length of the tube (surface to be ground) is 4" diameter x 10" long. Two assemblies would need to be ground. Tolerance on the roll is .0005" total runout over 10". Diameter tolerance of the roll is +/- .015".
If interested in quoting, please PM me and I can provide a drawing detailing the work.
Ben
EDIT: Tube wall thickness is .25", Overall length including shaft is 20".
Ben
