Ronniet
- Feb 21, 2011
- Amarillo Texas
Have a belt grinder I use that needs new wheels.
A set of 4 of them all made of T6
3 of them with bearings
First one is the Drive wheel to the motor and is 5" o.d 2" wide with recess for shaft, Bore shaft is .750
3 of the wheels are all the same size @ 2.250 wide and 2.875 o.d with a sealed bearing recessed into each end.
All have to be crowned for belt tracking and the edges radius not left sharp.
I will supply bearings and can supply Aluminum stock
I would buy from machinist depending on cost.
I only need one set of wheels at the moment.
I can press in all bearings.
I have no drawing but could provide pictures and dimensions.
Not in a hurry can work with your schedule
PM me or email me and will respond to all .
R.
R.
