RFQ: PVC Rod turning
Hi all,
Looking to move some production out of house. All of the items in this post are using same stock material: type 1 gray pvc rod .5" diameter. I would prefer to get all parts made by same shop because of this, however all bids should be itemized per part at listed qty. First qty listed of each part is initial order, second qty listed is reorder. If you feel inclined to add additional price breaks, please do so.
Please send quote along with lead times or questions to dan at avast marine dot com
Thank you,
Dan
100pc/300pc
http://avastmarine.com/cad/5_inch_shaft.pdf
http://avastmarine.com/cad/5_inch_shaft.igs
100pc/300pc
http://avastmarine.com/cad/6_inch_shaft.pdf
http://avastmarine.com/cad/6_inch_shaft.igs
100pc
http://avastmarine.com/cad/shaft_coupling.pdf
http://avastmarine.com/cad/shaft_coupling.igs
500pc/1000pc
http://avastmarine.com/cad/pegleg.pdf
http://avastmarine.com/cad/pegleg.igs
The job has been awarded. This RFQ is now closed. Thank you to everyone who took the time to look at our parts.
- You may not post replies
- You may not edit your posts
Forum Rules
