RFQ: Round Brass Part, Milled flat, Double Sided.
DanMorrison
Aug 2, 2012
Toronto, Canada
I have a small (7/16"OD x 0.815") brass part that needs flat bottom bores at both ends, a flat milled on the side, and a through hole tapped 4-40.
Here is my prototype part, on the right, ignore the brass sleeve on the left.
This part needs to have a smooth, but not tight, sliding fit when inserted into a Delrin Af sleeve. Length tolerance can be +- 0.005. The bores on each end need a tolerance of +-0.002
I am looking for a small run of 50 parts, but will need 200+ after that. First run of parts needed by early-mid September.
I can provide PDF/CAD upon request.
Thank you.
p.s. - The brass sleeve in the above photograph will be made in Delrin AF (with a slightly thicker wall), so if you can do both parts, that would be a bonus.
