Need 3mm & 4-40 face holes tapped 200 round pieces
  • Thread starter Guest
  • Start date
  • Replies 4
  • Views 3,255
G
Guest
Guest
Please quote the 12 tapped holes. You can quote with or without the two cross holes and also with or without deburring the backside of the tapped holes, please specify what your quote includes. The job is for 200 pieces, you will receive 205 or slightly more lathe blanks as shown in JPG 002. I will include a clean PDF and a completed sample with the blanks. Please also quote a lead time. I will have the blanks ready in a couple days. USA shops in the lower 48 only. Preference given to veteran PM members with a posting history. Send a private message with your quote including your e-mail address and business website if your have one.
Tolerances are
3/32 hole -.000/+.003
.070 hole location +/-.005
17mm bolt pattern +/-.005
Thread specs 2B (inch) 6H (metric)
PS I hold the O.D. to .824-.825 if that matters.
Material is 303 stainless
think this part would have been easier to do with live tooling in one setup vs made from lathe blanks. having to hold and load 200 pcs makes this very tedious.
