I need two molds made from aluminum. Molds will be used in a composite resin infusion process and will need a 3" flange welded around the outside once cut. Flange location is non critical, just needs to be somewhat near the top of the mold and the welds all solid.
I have two files for each mold. One without the flange and one with the flange to show approximate location (again, exact location not critical).
Upper Mold & Lower Mold
Tolerance: +/- 0.005"
Material: Aluminum 6061
Flange width: 3"
Flange Thickness: 3/8"
Exterior dimensions of upper mold (without flange): < 36" x 8" x 2.75"
Exterior dimensions of lower mold (without flange): < 40" x 6" x 3.5"
Due to software limitations, current files do not have a radius at the interior edges. A 0.5mm radius can be added at all interior edges for machining purposes.
I only have STEP files, no dimensional drawings. Please email me at [email protected] .
Pictures with and without flange
Flange width: 3"
