clarnibass
- Dec 23, 2015
Hi
I would like to get quotes for a part like this: ring with hole circle, with the holes overlapping the bore.
I don't have final measurements yet (will send to anyone who can quote) but the part is roughly 80mm diameter.
Bore and hole circle need to be centered/aligned pretty accurately but actual diameters are pretty loose, probably about 0.1mm off is fine (I'll have more exact tolerances later), as long as they match each other.
Material should be cheap and rigid, probably regular steel is fine. Aluminium could be fine too.
Attachment shows a paper mockup.
