To me any pallet truck with which you can lower a maximum capacity load in a controlled manner is good
Most of the cheaper onces cannot do that
I was about to say the same thing. I bought a Muliton 10,000 lb capacity manual pallet jack years ago brand new. Well, it would lift 10,000 lbs all right.... but it would not *lower* 10,000 lbs ! In other words, with that much weight you could not pull the lower lever at all....and even if you could it would have required so much force it would have not been controllable....the whole 10K would come crashing down at full speed. The only way to lower it was to tap the relief valve with a hammer, and even that was tricky to do.
I called Multiton about it and they sent me a different spool valve to install, which helped a lot but still not like it should be really. Most 5K pallet jacks are like that...you actually lift 5K but very difficult to lower that much in controlled manner.
These days I use electric pallet jacks for everything that is near capacity....just press a button to lower...built way more heavy duty....plus you have brakes* l But still use manual ones for light loads.....the best manual pallet jack ? Dunno....probably Crown or Rol-Lift, like others say....my manual ones have tended to be Jungheinrich or Multiton (same thing in some cases) and they are fine for about half their capacity but above that they suck.
*Even better, the newer electrics have AC motors and regenerative brakes...so if going slightly downhill for example, the pallet jack stops when you let off the "throttle". ..and it stops in unison with the throttle....i.e. smooth and gradual
The older electrics with DC drive the only way to brake it is to raise the steer arm, i.e. sudden braking only....so if going downhill you have to constantly throttle it in reverse to slow it down....tricky to do, but is doable. Still, the regenerative brakes are sooooo much nicer.
