Do electric walkie straddle stackers ever have tilt functions ?
Results 1 to 8 of 8
    Dec 2000
    Coastal Dogpatch, SC, USA
    50,596
    2360
    5200
    Default Do electric walkie straddle stackers ever have tilt functions ?
    Like this one..
    25 Electric Yale MSW4 Electric Walkie Straddle Stacker
    Can the forks be tilted back or forward any ? Seems unlikely but just wondering....I know they can on "reach" type lift trucks that are not all that different, so it would be possible to do....but doubt they bother on this style.
    Oct 2005
    erie,pa
    8,374
    15230
    4079
    I'm not seeing it listed.
    Are you seeing that large trunion on the mast ?
    As you know, the straddle type, ride on ones have tilt done
    up on the forks carriage (a little tiny cylinder pops the
    bottom of the forks out a bit to effect "tilt")
    And that fork carriage tilt could be added to a walkey IIRC.
    Dec 2000
    50,596
    2360
    5200
    I don't mean that particular one necessarily, but do any of that handle style electric walkie straddle type ever have fork carriage tilt capabilities ?
    Oct 2005
    erie,pa
    8,374
    15230
    4079
    Quote Originally Posted by Milacron View Post
    Well, there is that large trunion block on the mast just above the
    battery.
    One could surmise that there is a small tilt cylinder under the battery,
    parallel with the floor, doing the tilt of that mast.
    Aug 2007
    GA
    548
    87
    Never seen one with tilt, most have non tapered forks as well, with tilt you'd want tapered forks. I've got a Big Joe PDI that I need to run tilted back a bit sometimes- it has forks that mount on a bar so if I need to I can hang a spacer of 1/4" plate from the bottom rung of the carriage which gives 1" plus lift at the fork tips. Poor mans (non power) tilt...
    Aug 2013
    NY
    2,301
    980
    789
    We have a similar one at work. No tapered forks or tilt. Just up down with a manual wheel brake. The hydraulic pump runs off a large car or marine battery. It was used to help replace the very heavy lead acid battery in our Raymond lift. It held 1500-2000 pounds with no issue.
    Sent from my XT1053 using Tapatalk
    Oct 2012
    Virginia
    9,222
    4980
    4087
    Raymond has ones that can be - optional if not already inbuilt as standard, depending on model.
    They cannot be the only such supplier. May not be universal, but there's "some" longstanding need besides your own interest.
    Nov 2017
    INDIA
    Never seen with tilt function. I dont mean it is necessary tilt function in walkie straddle stacker
