alskdjfhg
- Feb 20, 2013
- Houston TX
For those that don't know, I'm going to be building a building here soon.
I'd like an overhead crane, but that's not gonna happen. The next best thing I figure is going to be a traveling gantry that runs down the shop on a track.
Yes I know this isn't the best solution and yes I know the issues about building something like this. At this point, it is only theoretical.
I know where there are some W33x141 beams, but I was under the impression that W flange beams weren't supposed to be loaded on the flange like it would be with a trolley, thought you were supposed to use an S flange for that.
But then I found this; http://store.americancrane.com/Asset/Crane-Comp-Drawings-and-Spec-CSL-1002-0407-opt.pdf
And in their charts, they are using W flange beams, and Goggling some of these questions leads to results to trolleys made for both S and W sections.
So what is it? Can a W flange be loaded with an underhung trolley or not?
What I would like (and at this point, it is theoretical) is a 35ft span 5-7.5 ton capacity. I figure these numbers are realistic because the PDF says they use W30x132 (with a 18x47.5 cap) for a 38ft span and a 10 metric ton load.
Thanks for any and all info.
