Scruffy887
Titanium
- Dec 17, 2012
- Se Ma USA
I am considering installing 2 of these. Harrington HPC500 Medium Duty Class B Cranes, 1 ton kits. These kits have the end trucks and bridge complete. Just need long runners and hoist with hoist trolley. It just seems to make sense for the $ involved. These are not powered in either direction. 2 of the 1 ton units in 12 foot will do more than I need but I have some questions. I would like to use a 16 footer for one space but the ceiling rails would be a max of 11 feet apart so the load at the ends would be cantilevered. I can compensate with extra rollers for bridge tilt but do not know just how accepted this is. I do plan on talking to the manf direct first.
Long rails will be hung from the ceiling beams. The longest section has a Southern Yellow Pine 12 x 12 every 10 feet, they span 24 feet for the floor above. The section that I want the cantilever located wouls have the ceiling rails running the same direction as the pine beams, hence the 11 foot spread.
Any thoughts?
Any thoughts?
