Gooseneck trailer anti theft locks, which is best ?
Page 1 of 2 12 LastLast
Results 1 to 20 of 32
    Dec 2000
    Coastal Dogpatch, SC, USA
    50,598
    2360
    5200
    Default Gooseneck trailer anti theft locks, which is best ?
    Something that inserts where the trailer ball normally would go that would be extremely difficult to remove without the proper key. Ideally not involving a padlock that could be sledge hammered off.
  2. Likes camscan liked this post
  3. #2
    16,732
    6939
    5226
    Quote Originally Posted by Milacron View Post
    Tough one, what with today's prevalence of short-use but tiny cutting torches and battery-powered tools with good abrasive cutting disks - even if stolen.
    Is it practical to make the section that mounts TO the ball into a removable section that can be stowed in the tow vehicle? Or if already removable, key or otherwise alter yours such that another, UN-altered one cannot be dropped in?
    Bill
    Dec 2003
    suburbs of Ann Arbor, MI, USA
    13,034
    423
    991
    Here is what I do.
    1) Take the crank arm off the landing gear/jack and store it inside. I also remove the bolt holding the driveshaft to the stubshaft of the jack-post. So to jack the trailer one needs a crank arm and a bolt/pin. These could be overcome but difficult if you didn't plan ahead
    2) Drop the adjustable collared post (that drops over the gooseneck ball) out of the trailer and store it inside. Again, it could probably be replaced or not needed by a rollback type setup, but damn hard to tow the trailer without a way to connect it to the ball.
    3) Store things on the trailer. Heavy things that would get thrown off and be an obvious red flag to cars on the road and would obviously get attn of law enforcement. To tie them down would need tie downs and some more time.
    4) Park truck in front of trailer where it's "in an alley" of sorts and really no way to move it any other direction.
    5) Assorted tricks with the truck so its "hard to start" and one would have to start troubleshooting.
    I try to put up a good challenge...
    Granted it does take me just as long to get the trailer ready for transport as I have to reverse all the steps. I don't use it every day, and so the PITA factor is acceptable.
    16,732
    6939
    5226
    .. and then there are wireless alarms that could be applied to something that has to be handled early-on in the theft-prep sequence.
    Those could set in-train any combination of events you care to dream-up.... some nastier and more immediate than others.
    Bill
    Jan 2008
    king george, va
    708
    151
    66
    Take a new ball and drill a 3/8" hole thru the bottom of the side of the stem. If you have the West Texas straight pipe down tube, lock the ball in and slide a piece of casing(heavy wall pipe) over the flange and weld a plate with a hole for the stem inside so a lock can't be mashed.
    If you have a ball receiver on it(both types use a ball), slide a piece of rectangle heavy tube over the receiver, notched for gussets and covering latch. Weld angle iron inside with just enough space to pass the ball stem. Slide lock in and attach to stem.
    If you have material necessary it takes about 20 min. to a**hole resistant a lock.
    A pic of the type you have would help.
    Padlocks are good if you protect them, you can't sledge a lock you can't get to!
    Ben
    Jul 2011
    Southern Calif US
    891
    8
    242
    I just have a tag trailer, but do 3 things to slow them down, and 1 final measure.
    1) chain the wheels together, usually on a "hidden" side, even if they do get hooked up, they arent going far with 2 back wheels locked.
    2) tounge jack cranks were removed and hexes cut in the top 7/16 socket fits with a cordless drill in low gear, they better come prepared for that.
    3) standard tounge lock with a heftey military padlock.
    4) last line of defense, motion detecting cellular alarm, it is progrmmed to call my cell phone and enter 777777 every 5 minutes when the trailer is in motion (only when armed)
    I guess a Lojack could be used as well, but you have to know its stolen before you can track it.
    16,732
    6939
    5226
    Quote Originally Posted by lazarus View Post
    Ben
    Now that we've covered it all in a Google-searchable manner, one or more of the aforementioned a**ho's out there has probably welded-up a clamp-on that resembles a Koala bear hugging a tree, can drive up, clamp his OWN rig onto the pillar, hook-up, and be rolling in a New York Minute with no more inconvenience than a six-inch offset from prior swivel point.
    Mot be just as well-off to simply get you a well-lighted sign:
    Please Stay In Your Vehicle when the Alligators are feeding!
    Bill
  9. #8
    Jun 2006
    Near Seattle
    4,268
    2228
    1005
    At the shop - aircraft tie-down buried several feet deep in cement. Very hard and heavy security chain run through said tie-down and the trailer frame and at least one wheel. This is of course useless when traveling. And didn't prevent somebody from cutting a box trailer open and stealing the contents - but at least the trailer is still there.
  10. Likes camscan liked this post
  11. #9
    Jan 2008
    king george, va
    708
    151
    66
    Well EXCUSE ME MR BILL. Seems like I was the only person to answer the mans question. Not anything about super duper alarm systems or anything. BTW we have used these lock covers on the east coast where I live without fail.
    READ THE OP
    Ben
  12. #10
    Jan 2008
    king george, va
    708
    151
    66
    Milacron,
    Obviously nothing will keep a determined thief from stealing your trailer. This is the only avenue you have to secure it. Remove the axles, tongue, deck, ramps, lights and wires. Bury the frame under 40feet of concrete 80'x80'. Make sure to put an alarm system on it before you start mixing the sacks of quickcrete.
    Happy Bill?
    Ben
  13. Likes greenbuggy liked this post
  14. #11
    Dec 2000
    50,598
    2360
    5200
    Milacron,
    Happy Bill?
    Ben
    I could set it on the loading dock with the forklift but then I couldn't get the forklift back inside as the trailer would be blocking all doors.
  15. #12
    Mar 2006
    Seattle,Wa
    733
    25
    At your own place with a forklift is easy, set it up on ecology blocks or even just one under the gooseneck
    should do it. Something portable you can clip on is more of a challenge..
  16. #13
    Jan 2008
    king george, va
    708
    151
    66
    With the forklift you have would the roof handle the trailer? Maybe paint it camo and park it in the woods.
    But seriously, a lock cover of 3/8" box will stop a quick hook and run. I learned a little trick when I worked for the county. All our trailers were wired wrong. All our truck plugs were wired wrong too. All wired the same. If someone took one they'd blow fuses and lights won't work.
    IIRC the center ground post and running lights were switched, the brake and left turn were switched. Grounds were hot and hot were grounds. The shop sup had a diagram in his desk and a pigtail that converted the trailers to normal in cases where we got a new truck in and needed it before we rewired it.
    You could rewire your trailer and make a pigtail like that and leave it locked in your truck.
    Ben
  17. Likes thermite, flatbelt liked this post
  18. #14
    16,732
    6939
    5226
    If you limit yerself to reading no posts but yer own, or think you can convert that to air-miles or a discount on diesel-fuel, by all means go for it!
    Bill
  19. Likes digger doug liked this post
  20. #15
    16,732
    6939
    5226
    Ben
    ..couple that with a delayed major smoke-generator incorporated into the trailer to attract tires-afire type attention once underway... and you might be instrumental in recovering not only the trailer, but the tow-vehicle they stole on the previous outing...
    Bill
  21. #16
    May 2003
    Weirsdale, FL
    1,778
    170
    With a forklift on your home grounds you could always position the gooseneck post up against a wall or something so it would be difficult to get to it with a truck.
  22. #17
    Oct 2003
    Pinnacle, NC USA
    1,092
    1453
    47
    Blaylock Inds. builds a nice lock. Their TL-50 or 53 will work.
    Blaylock Industries - EZ Lock Trailer Locks
  23. #18
    Norfolk England
    1,569
    1449
    963
    Default hitchlock
    Go to your local caravan dealer and look at the locks for different hitches. My present one I have a removable post in the ground with a ball fitted to it, park the caravan, insert post, swing caravan round, drop onto ball and lock with proprietry hitchlock. I can tow with this type still fitted and when I pitch the caravan I have a plastic ball (supplied) to stop you putting a temporary whatnot into the hitch, not worth the effort to try to get past that unless you have time and privacy My present hitch is a Winterhoff, my previous two were Alko, Iprefer the Winterhoff
  24. #19
    Dec 2000
    50,598
    2360
    5200
    Quote Originally Posted by Weirsdale George View Post
    That's pretty much what I have been doing sucessfully for years. Place it against the dock wall such that no way a truck can back under the neck to actually get it out. (plus remove the landing gear crank handle) But figure someone determined enough could probably drag it from the wall with a chain...hard to say...with 8 wheels of friction on a 6,000 lb trailer, maybe not....perhaps I should try it sometime.
    I figure the ultimate would be to somehow create a hole in the dock floor large enough to set the neck in with the forklift. They could raise the landing gear and crank it up on blocks to get it out of hole but then how to drag it from dock without it crashing off the blocks....
  25. #20
    Dec 2000
    50,598
    2360
    5200
    Quote Originally Posted by camscan View Post
    Here "caravans" typically use "5th wheel" arrangements similar to semi trucks. They are unlikely to have anything for gooseneck trailers.
