I have to unload this mill from a trailer in 2 hrs or so, and Mill isn't visible now. I know there's a 1-inch or so threaded hole in the top of the mill casting. Is that for a lifting eye and if so anyone know the shank dia. Of eye it takes? If no lifting eye provision on it, would you lift it with a strap around neck or what? I just know this machine doesn't want to be pushed across a wood trailer bed, the lead edge just digs in. Anyone know the listed weight of a 2CH vertical K&T offhand? I thought 4500 lbs but it feels heavier when towing. Replies asap greatly appreciated.
