M. Moore
Titanium
- Jun 8, 2007
- Vancouver Island, B.C. Canada
Looking for a way to flip products using an overhead hoist.
Slab of wood up to 5' wide and 14' long, 2.5 to 3.5" thick, max weight in the 500 to 600 lb range.
I have been brainstorming to come up with a workable solution and wondered if something already exists.
One idea was to grab from both ends and rotate 180° then set down. Clamping the product securely is an issue no matter how it is flipped, currently we have endless slings and rotate the large wood slabs in the slings and then set down, this works but is very slow and cumbersome. Having to set the slings each time is a pita.
Ideally the flipper can grab a slab from the top of the pile and move it into position and or flip if needed.
Is there a 180° capable heavy duty powered knuckle joint? The grabber could be hydraulic or mechanical and I have a few ideas on how to make that work. With the knuckle joint setup the slab would be grabbed from one edge and flipped, the movement of the slabs' position is not a problem as they don't have to be flipped in place, just flipped and the overhead hoist can easily reposition onto the table.
Thoughts?
Michael
Thoughts?
Michael
