nt1953
Hot Rolled
- Sep 4, 2004
- Huntsville, Alabama
Much of the equipment and storage I have in my home shop is on casters so that I can move things around when I need to. I have always just muscled things into place. However, I recently purchased a Milwaukee (K&T) 2K universal mill, and at over 6000lbs, it just is too much to push around, even on casters. So, I began to look around for a non forklift solution to moving heavy loads.
The Powerattack MYC25CC caught my attention: POWERATTACK TUGS MOVE UP TO 3 TONNE WITH EASE - YouTube
I could not locate a dealer in the US, and I figured it would be too expensive anyway, so I decided to build one.
I felt like the main problem would be finding an inexpensive worm gearbox that I could use to power the wheels. I ended up settling on an unusual solution. I decided to try a small tiller gear box I found at Snow Joe. The gearbox is part number TJ601E-29 and can be found here:
Sun-Joe-Replacement-Gear-Box-for-TJ6 1E-Garden-Tiller-–-TJ6 1E-29
If you decide to buy one of these, make sure they ship the plastic piece shown in the picture that connects the gearbox with the drive shaft. The part number for the plastic part is TJ600E-43.
Once I had the gearbox, I decided to use a Dewalt model DW130VR to power the tow motor. I wanted a variable speed drill with multiple handle mount locations to make it easy to mount the drill to a long handle/tow motor spine. I bought a factory refurbished one at CPO Outlets here:
Factory Reconditioned Dewalt DW13 VR 1-2 in. - 55 RPM 9. Amp Spade Handle Drill
Finally I purchased two 5" polyurethane tired caster wheels from eBay. I removed the bearings and made bushings to fit the axle on the gearbox. I installed two 1/4" threaded pins into each bushing, and drilled holes to pin the wheels into existing holes on the gearbox axle.
