How to properly raise a machine that sits on the floor?
Results 1 to 19 of 19
    Apr 2018
    20
    26
    Default How to properly raise a machine that sits on the floor?
    I have a bulky (3000 lbs) milling machine, that stays on the garage floor. There is a tiny gap (3/8") between the machine's base and the floor. I want to lift the machine a little bit to install adjustable rubber legs. What is the proper way to do this? I think about a breaker bar, but I don't feel like it's safe - there is a lot of load and tension on the bar and it puts significant stress on the bottom of the machine, which is made of cast iron and may crack. The only crane I have is a 2-ton cherry-picker crane which I have really terrible experience with - last time I tried to lift the mill with that crane, it almost tipped over on me.
    Thanks!
    Oct 2009
    Portland, Oregon
    3,575
    3825
    1755
    A breaker bar is used with sockets to break tough bolts loose.
    A riggers bar is a large prybar for lifting machines.
    You could lift that little thing with a claw hammer or a 2' prybar. If that's scary for you then just drive wedges in.
  3. Likes digger doug liked this post
    Nov 2008
    Madera county california usa
    2,079
    18
    480
    Right in the front of the photo is a hole for bolting machine to floor.
    Usually sized close for 5/8 threads.
    Check hole size and drill out as needed to allow tapping for bolt.
    Now use long all threaded high grade bolts to simply raise the machine carefull and slowly straight up...1/4 turn on each foot going arround it.
    Place blocks or other spacers to support as you go.
    The adjustable feet may have stud mount so tap to same size.
    We lifted our 6800 pound L&S 6 inches to allow pallets under it this way.
    Sent from my SAMSUNG-SGH-I337Z using Tapatalk
  5. Likes itsmeBernie, Illinoyance, Yan Wo liked this post
  6. #4
    Oct 2010
    Oregon
    4,273
    2836
    1402
    A pinch bar or other heavy lever is the way to get started. (Around here, a breaker bar is a non-ratcheting socket wrench handle.)
    You will need a stack of 1/2" hardwood plywood (better) or metal (not so good, slippery) plates at least 3x3" or 4x4" (6x6" is much better when the stacks get higher), perhaps a comparable stack of 2-3" thick hardwood blocking, a pinch bar, and ideally a toe jack. A second human with enough common sense to keep fingers out from under the machine can also be a real help.
    You can possibly use high-quality softwood plywood, but my limited experience is that it will crush under the machine feet and end of the pinch bar much more readily than the hardwood plywood. Cheap CD plywood with internal voids filled with putty is strictly to be avoided for this procedure! Consider a sheet of hardwood plywood as an investment in your rigging tool kit. BTW, hardwood plywood here means all the plys, not just the wafer-thin veneer on the faces.
    Using the pinch bar, raise one side of the machine and slide a plywood plate under each foot on that side. Make sure the foot bears on the center of the plate, not just near an edge (much less just near a corner). Move to the opposite side of the machine and repeat. If that's not high enough to get the toe jack under the edge, put a plywood plate on the floor where you were using the pinch bar and repeat. The machine is now 1" higher off the ground, which should be high enough to get a toe jack under the edge. If you don't have a toe jack, keep raising all the stacks 1/2" at a time, including the fulcrum stacks for the pinch bar.
    If you need to protect the finish or surface coating on your floor, put a thin plywood plate under the pinch bar fulcrum even for the first 1/2" raising.
    If you have a toe jack, after the machine is high enough, get the fulcrum plates out of the way, and use the toe jack to raise the machine more than 1/2" at a time (don't be reckless and tip it over), and increase the stack height accordingly. Alternate sides until the machine is high enough to get rollers, leveling screws or whatever under it. For convenience in manipulating the stacks and greater piece of mind, you can replace bunches of plywood plates with thicker blocking when the machine gets that high.
    Now, if you put the plywood plates squarely under the machine feet, the odds are good the stacks of blocking are going to interfere with whatever you want to do with the machine. Not a major problem. The machine is now at a proper height. Work on one foot at a time. Put two stacks of blocking next to each foot. They will be a bit short. Raise that side/corner of the machine just a little bit. Pull out the original blocking stack and bring the two nearby blocks up to full height and set the machine back down again.
    Tony's suggestion of tapping the base holes and jacking it up also works, but the ends of the jack bolts will grind into your floor a little bit. You also need to be prudent about how high you jack it up. Columns under compression will deflect abruptly, when either the load or the length gets too large. I would treat anything under 3/4" jack bolts like the pinch bar, and continually update the stacks of blocking as you raise the machine. That way, if anything goes wrong, the machine will be caught before it falls or tips very far.
  7. Likes lienjohn liked this post
  8. #5
    Oct 2017
    49
    13
    22
    Tip the machine with a ratchet strap or whatever and "wobble" it onto higher and higher shims.
  9. #6
    Sep 2008
    CANADA
    Nova Scotia
    218
    12
    101
    Quote Originally Posted by Tony Quiring View Post
    Jeez.. all that to avoid using a heel bar in the pockets provided for that very purpose?
    I guess I could see doing it for a 7k lb machine (although at that point I'd rather use toe jacks), but this is 3000 lbs - you could lift it with a straight pry bar and some blocking, or hell, even with a 2x4 if it didn't have any knots.
    OP, don't overthink it - stick a lever under it and pry it up. There's no science to it.
  10. Likes m16ty liked this post
  11. #7
    Jul 2012
    Washington
    2,052
    744
    808
    Riggers bar and 2x6 scraps. Go slow and don't lift it more than you need to for the next block. Having a helper makes it go easier but a luxury I rarely have, wife isn't into this stuff.
  12. Likes digger doug, Illinoyance liked this post
  13. #8
    Apr 2018
    20
    26
    Thank you guys for all your replies! The answer for me was "riggers bar", which is also called "pry lever bar". I will order one right now - life is awesome!
  14. #9
    May 2011
    New Jersey
    429
    8
    138
    How do you plan on adjusting them once installed?
    I use a rigging bar to adjust mine and have it sitting on shims
    Sent from my 2PS64 using Tapatalk
  15. #10
    Feb 2012
    The warm desert of Phoenix Arizona
    1,208
    259
    410
    I use a burke bar...
    Cheap from Homedespot
  16. #11
    Aug 2007
    GA
    578
    94
    I prefer a stair step pattern with 1-1/4" treads and 3/4" risers cut into 4 4x6 blocks. A lot less stuff slipping around than with individual small pieces when trying to lever up a heavy load, plus you don't need to worry about pushing a piece under the machine by accident.
  17. Likes sfriedberg liked this post
  18. #12
    Aug 2015
    Illinois
    834
    690
    353
    I moved two mills and three lathes the last couple weeks. We could have used pinch bars and blocking to get it high enough to get skates under it. Instead we used a cheap Chinese toe lift jack. It saved a lot of work and, in my opinion, was safer.
    Before raising the machine I suggest blocking it up high enough to get your fingers under it. Feel around below the screw holes. I think you will find there is no iron directly below the screw holes that would bear on your anti-vibration pads. You could tap out he screw holes. Remove the studs from he pads. Countersink the tops of the pads. Use large setscrews through the tapped holes. They would bear on the countersinks in the pads. As Tony said you can use the screws to raise the machine. Use temporary blocking (one corner at a time) to hold the machine up as you install the pad and run the screw down into the countersink.
  19. #13
    Dec 2000
    Coastal Dogpatch, SC, USA
    50,723
    2447
    5281
    With a mill you have a built in screw jack... cut a 2 x 4 of appropriate length to wedge under the table (ideally near to the Z screw as possible) and crank the table down on the lumber.
    Once high enough place something in the "center of gravity" middle of the base and crank table back up. Rock machine down so that rear of machine is up off floor. If still not high enough place lumber under back, rinse and repeat procedure until it is high enough.
    Of course a toe jack would be even easier.
  20. #14
    Oct 2013
    South Dakota
    162
    1673
    61
    just curious- does one really want rubber feet under a mill?
  21. #15
    Apr 2006
    Manchester, England
    6,974
    863
    3935
    Quote Originally Posted by Milacron View Post
    I've done it that way before. On a " Bridgeport " I've put the timber under that bracket that carries the cross axis leadscrew. You're only lifting half the machine at any point. I'd be careful on anything much heavier than a " Bridgeport " though.
    With a 3000 lbs machine I think you'd be OK with those rubber mounts. The manufacturers usually tell you what each individual mount will carry.
    Regards Tyrone.
  22. #16
    Dec 2004
    uk
    12,476
    3490
    5597
    Quote Originally Posted by DrHook View Post
    Yeah mine sits on rubber pads on the corner of the base were the rasied feet are cast in on a bridgeporrt textron machines base, no - with out issue as does my lathe. IMHO the real risk is the feet the OP is proposing to use and using them in the bolt down holes, IMHO that puts them too far in and makes the machine dangerously tippy, most the old machines had bases and are designed around sitting on the rim of that base, the bolt down holes are for just that, bolting it down, putting feet there that far in under the machine and things are way to unstable for my liking.
  23. Likes DrHook liked this post
  24. #17
    Apr 2004
    Modesto, CA USA
    5,689
    839
    I think people have failed to properly understand the OP's question. . if the machine is really floating 3/8" off the floor he can just increase the anti-grvity generator until it is high enough to attach the rubber pieces then turn it off slowly and allow the machine to settle down onto the new leveling feet.
    I think it is very dangerous to tip the machine while the antigravity is on. A slight angle could cause the machine to tip over at a extreme angle with no warning.
    Bill D
  25. Likes tdmidget liked this post
  26. #18
    Dec 2007
    Central Ohio USA
    3,573
    42
    1589
    Best/cheapest source of shim wood is oak pallet slats. Thin, wide, rough and free.
    Just did this recently on my Toolmaster. 5' bar was enough, as long as someone else was sliding in the wood. Don't use 2x material, as you won't be able to lift that high in each bite, and you want to limit how far it can fall if things go awry.
  27. #19
    Apr 2018
    20
    26
    Quote Originally Posted by Bondo View Post
    The feet are adjustable. If you rotate the bolt, the feet base would raise or lower against the rubber pad. They claim 2000 lbs of weight capacity each. The model is: Sunnex Machine Mounts 10002
    Quote Originally Posted by Illinoyance View Post
    That's what I ended up with.
    On my mill the table would resist only to down force, but not to the lifting force. It will simly separate from the machine's base, at least that's what I read from other people.
    Quote Originally Posted by adama View Post
    I kind of realized that. The user's guide for the machine doesn't mention how to mount it. The machine was first made in 1956, may be they didn't concern about mounting those days. What are my options? I think about putting a steel strip or a C-channel underneath the mil, make it extend a few inches sideways out of the mill base and put rubber feet into the extensions.
    Quote Originally Posted by Bill D View Post
    Bill D
    I tried that, but instead of machine lifting up, my entire house went down and now it's half buried underground. They should have mentioned that in the user manual, unfortunately it was in chinglish.
  28. Likes sfriedberg liked this post
