I've got a 5500lb rail type lift gate that is a large bifold platform that hinges at its connection to the truck and is held level by 1/2" chain at about a 45 degree angle that extends from high on the rail to the tip of the platform at either side. I would like to add a few inches of adjustment to the chain so I can level the lift gate platform when the truck is parked on ramps or sometimes to aid in rolling cargo on to the platform - usually I'd like the tip lower. I'd like to do this with a pair of detachable handle load binders. Because of the way the gate folds and chain routing there is not a lot of space for shackles and such so the ideal type of binder would be a jaw and jaw type so the chain could be attached directly to the binder without any additional hardware. I've not been able to find these from a quality or non China manufacturer. I can get a hook and eye type binder from CM (#46566, 9200# WLL) and cut the hooks off but I'd still need to use the links between the OEM hooks and binder eyes PLUS a double clevis to attach the chain, and at both ends. All of this makes the assembly too long and not very tidy. The binder eyes have a 1.02" ID, .61" section and 2.25" OD, so a shackle of adequate rating will no pass thru the eye. Any quality brands I might search besides CM for a jaw and jaw type? Is there some piece of hardware I may not be thinking of that can join 1/2" chain directly to this size eye? (other than making side plates and bolting thru both the eye and chain with 1/2" grade 8 bolts)
Another issue is with the angle involved I'm looking at about 2x what the load would be on a vertical chain, so 11000 lbs/2 plus a good bit more if the load isn't centered. I noticed the CM site says the "size" of the binder g43 is 1/2 and g70 is 3/8, for this model- not separate 1/2 and 3/8 models. To me it looks like this means the assembly has a 9200 WLL with 3/8 g70 OR 1/2 G43 chain, but CM 3/8" G70 chain has a WLL of 6600 so that's not clear to me. My guess is the existing (painted, not plated) 1/2" chain on the gate is G43, 9200# WLL. I want to be sure the CM binder is adequate for the job. Riggers weigh in please...
Tom
Tom
