Obsolete Trailer Wheels? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21
    Oct 2005
    9,573
    16676
    4881
    Those axles are so cheaply made, I recall reading somewhere, that the tube itself
    was a wee bit thinner, special made thickness, just for the MH axles makers.
    I torched apart an old MF (the building was long demoed, and this was half in the dirt. The springs were single thick leaf, not very safe in case of a crack.
  2. #22
    May 2016
    Tennessee
    298
    50
    158
    Dayton type wheels aren't illegal, you can still order them new on class 8 trucks. Lots of people with dump trucks and heavy haul trucks still prefer the Dayton hub, as they are stronger than a Budd hub/wheel combo.
    As for house trailer axles, I'd think they would be legal as long as the tires were DOT rated. I know the only local mobile home outfit around here will take the axles out from under any mobile home they install, they then return the axles, wheels, and tires back to the factory to put back under a new home. They always have a pile in the corner of the lot but I haven't looked at them close. You'd think they would be pretty good if they ship them back to the factory to be reused.
  3. #23
    Oct 2005
    9,573
    16676
    4881
    Thinking, and getting an inspection sticker on a trailer every year
    are qty (2) different things.....
  4. #24
    Mar 2006
    Seattle,Wa
    755
    21
    30
    Quote Originally Posted by m16ty View Post
    Maybe different regional nomenclature or I’ve just always been wrong but in the day we called bolt hole rims similar to but not interchangeable with Budds
    “Daytons” and 3 piece clamp-on-stud split rims like on MH or older container chassis “California Rims”. They are still all over the roads in US but I can’t imagine anyone spec’ing them on a drive axle for any truck. Also don’t understand wanting tube tires anymore and thats what you get with split rims.
    A quick look up close under a house trailer will reveal how flimsy many of the
    frames, axles, and crappy suspensions are.
  5. #25
    Jan 2008
    southern il
    551
    78
    188
    I saw a set of wheels on MH style axles one time, they had a heavy band of steel around the inside diameter of the wheel (probably 1/2 inch thick), it had the five bolt holes in it that allowed it to seat on the hub without the clamps................sure would make things easier.
    I worked on Dayton style wheels for most of my working life, so lining them up was no real problem.
  6. #26
    Aug 2011
    new plymouth id
    261
    22
    69
    here is brand new DOT approved 14.5s 1 NEW 8-14.5 Tow-Master LPT Bias Trailer Tire 8x14.5 8 14.5 14 ply Load Range G | eBay
    they are still in use around here but mostly home built trailer projects. but they get inspected and issued plates. east coast may be different. I didn't like working with them at all. every time dad had a mobile home moved we would make sure there was at least 2 spares and most of the time both would be blown, and we moved a lot of trailer houses.
  7. #27
    Jul 2009
    Peoria, IL
    10,981
    41
    8257
    I run a trailer with 8X14.5 tires. Never had an issue. Mine are factory Dayton/Fayette axles with bolt on backing plates. I run G rated tires.
    The axles to avoid are the true mobile home axles with welded on backing plates. You cannot replace the brakes. Plus they are usually 10 feet wide and will have been shortened for use on a normal trailer.
    Dayton rims are stronger than other rims for side loads. That's why you often see them on offroad rigs like dump trucks and logging trucks. Plus, the wedges that hold the rims on require pretty light torque, so you can easily change tires in the field. Hub pilot semi truck lug nuts are 450 ft-lbs or more depending on the last hero that rattled them on with the 1" impact.
  8. #28
    Jan 2008
    southern il
    551
    78
    188
    Quote Originally Posted by idacal View Post
    I hear you talking, if you don't push the weight limits, they don't do too bad.............However,
    If you notice, trailer toters have a full rack of spares behind the cab........that isn't by accident. A good 95 degree day makes them want to hatch out
  9. #29
    Aug 2005
    Tucson AZ
    5,877
    7992
    2685
    Quote Originally Posted by jmead View Post
    Now that's fucked up.
