Now not leaking a drop, but the temp needle gradually climbs such that 20 miles is about the limit before I need to stop. Some may recall I had a leak between the timing cover and the block, which would have been a monumental PITA to fix via proper means, and therefore I took a chance on Bars Leak. The concoction did stop the leak, but I'm guessing it also stopped up something else.
So, the question is might a high pressure flush, dislodge the clog ? Could be a new pump impeller and/or themostat might help but almost certainly the main issue is a clog somewhere in the system caused by the Bars Leak. I say this because when it leaked it did not overheat as long as it had water...only when the water level got low did it begin to overheat. Now it has plenty of water but apparently is not circulating everywhere it needs to go.
Thoughts ?
1996 Hino FB series with turbo diesel, 360,000 miles, runs perfect except for overheating.
Thoughts ?
