diyengineer253
Hot Rolled
- May 30, 2013
- Seattle, WA
Yeah, use two! I just pulled four 5500+ items off a truck where I knew one jack would be marginal, but fortunately the pallets allowed two to go in side-by-side. A little tricky steering the two together, but it worked out well.
If you have any regular 1000lb dollies you could also try jacking one side of the pallet up, pushing a couple of the dollies under that end, then use the jack on the other end to lift and control motion. Just be careful if going over any dock plates or similar height changes.
Most 5500 lb manual pallet jacks won't pick up 5,500 lbs without some damage to the forks. What usually happens is the forks spread apart by a noticable amount and the jack is never quite the same again.Anyone have stories of using a 5500lb capacity pallet jack to successfully lift more than 5500? Need to move just 4 heavy items a few feet on smooth flat concrete. Don't wanna buy a new 8000lb jack if I can wing it.
Also it's one thing to pick up 5,500 lbs but quite another to actually move it. Anything over about 3,200 lbs is pretty difficult to move by hand even over smooth level concrete.
You can buy them dirt cheap used. I once bought 3 Clark 6,000 lb electrics at an auction for $30 each ! (yes, thirty dollars) And all three worked fine. These days I use a Jungheinrich electric 6K with 4 foot forks I bought brand spankin new (but at deep discount due to being "on sale/last years model") and a late model CAT electric 6K with 8 foot forks.electric pallet jack would be a nice luxury,
Are you serious ?? I never cease to be amazed at how inexpensive manual pallet jacks sell for new.see if I can't find another used jack. They are so expensive new
I've done that before with a 10,000 lb capacity manual pallet jack and 8,000 lb load...pretty slow go but ya do what ya gotta do sometimes.Or just "ease" it along with a pry bar if you don't mind messing up the surface of the concrete a bit.
$550 for an 8K capacity manual pallet jack sounds dirt cheap to me. The Liftrite versions are two or three times that expensive new. As for used, I don't know that I've ever seen an 8K capacity manual pallet jack for sale used. Seen a few of the Liftrite 10K ones used for sale, but never an 8K.I was talking about the new pallet jacks cost of $550 dollars for a 8000lb capacity unit. $550 is a lot considering how many used secondhand ones can be had for around $100.
I keep preaching the charms of electric pallet jacks on PM but don't know if I have a single convert yet. All I can say is I'll keep preaching as it's night and day difference...electrics are infinitely better* than manual for loads over 1,000 lbs.
Yeah, I know. I'm hearing that is because they are using Tapatalk to sign up which doesn't have a place to enter location on the form. I keep meaning to look into that.Lots a new members are signing up with no location displayed more and more.
Who has an 8K pallet jack for only $550 ?? FWIW, when they get up to that capacity, the forks need to be made of channel iron rather than formed sheet metal. Also they need all steel wheels...no poly coating. Look at the weight, if not around 300 lbs or more it probably won't really lift that much without damage to itself. The Liftrite 10K pallet jack looks nearly identical to a normal 4K one but weighs way more....over 400 lbs.
Wow...that is dirt cheap for an 8K manual pallet jack. Seems a little light weight for that, but maybe it's ok. I'm still wondering where the used 8K jacks are for $100 as I've never seen one.
Notice
