Pallet Dolly Experiment - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21
    Jun 2016
    Virginia
    604
    337
    65
    bf0c1b99-c2a0-4233-b262-7a63dfcc6440.jpg7a40c7fb-f47f-4f26-97f3-df7e45ac3cb0.jpgHere’s a little more on how to use roller conveyors in trailers. See additional photos. Don’t follow the bad example in one photo showing light stuff in front and heavy stuff near tailgate, should be the reverse, but since we were only moving a couple of blocks at 20 mph or less, doesn’t matter much. We put Triwall cardboard pieces under each skid to prevent the occasional hangup that happens when some feature on pallet bottom hangs up on the rollers. The rear pallet doesn’t particularly benefit from the conveyors since forklift can place and remove it with no rolling, but both pallets in front were pulled by hand to the rear to allow fork access. Middle one was hundreds of pounds, one on right was only about 150 lbs. Use spare pallets or something as dunnage in front or behind load to prevent load movement due to inertia.
  2. #22
    Nov 2003
    Phelps, NY, USA
    1,636
    894
    316
    Quote Originally Posted by Cannonmn View Post
    ... I do try and be safe as possible under circumstances, for example we bought steel-toe safety shoes for both temps, they wore them one day then never again. We bought a mancage to put on the forklift when someone has to go high up, and neither will go near it, I think they still go pallet surfing when I’m not around, just two old guys with attitudes that no one’s going to change. We have hardhats for head-hazard situations; they’ll never wear ‘em. They do wear the face shields we have when they use the grinder or wire wheels, the only pieces of our safety equipment they’ll use. No idea why that and no other, go figure.
    In the shops and factories I've worked in that had the best safety, management wasn't too concerned about employee attitudes. What they cared about was behavior and if behavior didn't change they were dismissed. Not using safety equipment just wasn't tolerated.
  3. Likes digger doug, Monarchist liked this post
  4. #23
    Aug 2003
    New York
    60
    7
    If THEY are not careful you may end up working for them...
  5. #24
    Sep 2008
    CANADA
    Nova Scotia
    181
    9
    66
    Fire those dumbasses and use the money to buy a couple of fucking pallet jacks. You've probably already wasted $500 of materials and your labour cost cobbling together a number of dangerous shitty "dollies" that don't work half as well as a pallet jack.. if you'd just bought two of them at the beginning you'd have broken even!
    Edited to add: Heaven help your boss if one of the aforementioned dumbasses decides to forklift one of these "dollies" onto racking and it rolls off and kills some unsuspecting guy.
  6. Likes digger doug, Monarchist, Garwood liked this post
  7. #25
    Aug 2006
    greensboro,northcarolina
    2,099
    102
    374
    Isn't that what dock carts are made for?
  8. #26
    Jun 2016
    Virginia
    604
    337
    65
    I like these pallet dollies and may make a few more. There are so many other more likely ways to be injured or killed in a shop that fear of being run over by a runaway pallet dolly is pretty near the bottom of the list. Friday I had to leave town at a certain time and was running late. Needed all the room in the truck empty so I rolled the 4x8 foot pallet dolly up to the truck and threw everything on the pallet dolly and dragged it back inside; very handy for that sort of thing.
    Attached Thumbnails Attached Thumbnails 92947680-9870-4db9-9afa-7c9e9089be1a.jpg
  9. #27
    Jun 2016
    Virginia
    604
    337
    65
    Quote Originally Posted by RJT View Post
    Those are made for similar purposes but cost money I’d rather spend on tooling and other things I can’t make myself.
  10. #28
    Jun 2016
    Virginia
    604
    337
    65
    Quote Originally Posted by isaac338 View Post
    Thanks, have 7 pallet jacks (4 working, 3 awaiting repair), 1 electric pallet jack, 1 electric stacker, 1 propane forklift. And an electric tipper.
  11. #29
    Sep 2008
    CANADA
    Nova Scotia
    181
    9
    66
    I don't get it then... why not use one of the 4 working pallet jacks, and then use the time and money to fix the other 3?
  12. #30
    Jun 2016
    Virginia
    604
    337
    65
    There’s very little money involved, I buy heavy-duty casters with broken 5” wheels very cheap, then order the excellent poly-tired cast-iron wheels for $8 ea pls shipping, order 4 at a time to economize on shipping. Takes only a few min. to change wheels on the caster bodies. For me, very arthritic, bad knees and hip etc, walking across shop to fetch pallet jack is a pain, much easier to just pull or push the thing out of the way in the crowded shop. And I think building pallet dollies is fun, and one of a short list of mechanical skills I’ve mastered. If anyone wants link to the cheap but excellent wheels, I can provide.
