Clark Hurth/Dana Spicer 212 Super Tractor axle.
Planetary gears in the hub being replaced, and one of the four pinion gears came without the inner bore finished (which is also the roller bearing outer race). It was never ground. Due to time crunch, I got good measurements and finish bored the gear. Bore arrived .0154 undersized, so I just needed to skim that off.
I practiced on one of the the old gears, with consistent results, perfect finish. Took off .002 per pass, then .001 per pass consistently.
On the new one, same great finish... BUT! On the last spring pass, (no cross slide adjustment; just reversing back out), my boring bar took a nice initial cut and removed .005 instead of just under .001 as I was repeating before. It is now .005 oversize.
Noticable play when bearing assembled and installed on shaft.
My dumb question: Is this a major no-no to use as is? I know the forklift's weight doesn't rest on this planetary system, just drive from axle shaft to wheel. I think I already know the answer, but would love to hear scolding/advice.
