Road trip for a hydraulic press
Results 1 to 8 of 8
    Jun 2007
    Amarillo, TX
    1,116
    9
    35
    Default Road trip for a hydraulic press
    Amarillo, TX to East Dallas for this press. I was very nervous hauling this with it upright but we made it.
    Dec 2007
    Central Ohio USA
    3,407
    19
    1478
    Glad you made it safely, so all's good.
    Armchair quarterbacking: Constraining the base movement with timbers, and affixing chains all the way at the top would make one less nervous. Using transport-rated chains instead of the shiny silver ones would make the cops happier, if they happen to be looking. But it doesn't look totally unsafe for normal traffic conditions.
    I aways try to tie things down well enough so that you could pick up the load and shake it, and the trailer wouldn't fall off. Somewhat overkill, of course...
    Carry on!
    Chip
  3. Likes Adwcali liked this post
    Jun 2007
    Amarillo, TX
    1,116
    9
    35
    I hear you, wooden floor boards were deflecting down so maybe a steel floor trailer should have been better for the job?
    Dec 2007
    Central Ohio USA
    3,407
    19
    1478
    In general, four oak 4x6 timbers through-bolted into the legs will spread the load, as well as make the whole assembly less tippy, so moving it with a pallet jack becomes easy*. Also, when loading up, look not only at the fore/aft positioning with respect to tongue weight, but also where the point loads hit with respect to the trailer frame members. Some flat utility-type trailers are designed and rated for the weight you're handling, but only when evenly distributed, not point-loaded. You may find there's only one or two 2" angles under the load when it's in the "right" position. Moving fore/aft and ballasting with the rest of your rigging gear, pallet jack, concrete blocks or mother-in-law (optional) may be needed.
    *As long as you're only lifting it 1/2" or so. Still tippy if raised up high.
    Chip
    Jul 2009
    Peoria, IL
    10,629
    36
    7906
    Looks like a nice job chaining it down.
    Apr 2015
    172
    256
    57
    Quote Originally Posted by Shawn Ghormley View Post
    No wood decks are always better. Just checkout big trucks flat beds with metal decks are rare.
    A load will bite into a wood deck where on a steel deck it might as well be a sheet of ice.
  8. Likes moonlight machine liked this post
  9. #7
    Oct 2005
    erie,pa
    8,353
    15211
    4063
    How abouts you STOP posting multiple threads on this same
    press ?
    http://www.practicalmachinist.com/vb...-press-341834/
  10. #8
    Oct 2017
    7
    Quote Originally Posted by Chip Chester View Post
    Carry on!
    Chip
    Any time I move anything (usually 20' sticks of pipe on my roofrack, or a vertical compressor or something, but never really with a trailer) I always floor it and slam on the brakes and get out and check strap tension. I would much rather lose a load in a parking lot than on the freeway.
