secrets of the Hilman roller
JHOLLAND1
Titanium
Oct 8, 2005
western washington state
some years back we bought 10,000 lbs of Hilman rollers
actual number was 10 individual units--each one thousand lbs in weight with load capacity of 880,000 lbs each--- all Hilman products are metric ton rated
they were unused surplus from the local naval shipyard--- in use welded to nuclear reactor containments in surface ships and subs undergoing
---shipbreaking----takeout reactors scale 2.4 to 2.8 million lbs- reactors routed to Hanford or Idaho repository --the rollers allowed transfer to barge
so today i am curious about construction of the popular 10 ton skates and do teardown
main surprise---manufacture is in metric units--12 individual rolls are in the 10 ton dolly each roll 80 mm long with 30 mm diameter
four of these bear full load rating of performing unit--22,000 lbs
actual contact area of 10 ton roller is one square inch--combined contact area of all four laden rolls --thats 22,000 psi--but of course not concentrated in a 1" by 1" square
video link demonstrates home made skates used in moving 5500 lb Mori sl-1 lathe--i am driving truck:)
Machinery Moving with a Tow Truck - YouTube
The Hilman type rollers work ok but will chew up a concrete floor at heavier weights, if you don't run them on plates. We tend to go with regular steel wheel rollers on anything over around 10 tons, if we don't plate them.
Hertzian Contact Stress Calculator
looks like 1000 pounds on a 1 inch diameter roller, 4 inches long, is about guaranteed to blow up your concrete floor, with Hertzian sheer stress on the order of 10,000 psi, compressive on the order of 30,000. (assuming concrete is 50GPA)
100 pounds might still be enough: max compressive stress is 10,000 pounds and sheer stress is 3,000.
