Mickey_D
Stainless
- Apr 18, 2006
- Austin, TX
I have a Toyota 6K lift from 1999 that has a LP gas GM 4 cylinder engine and over the last year or so it is running worse and worse. The lift has about 12K hours on the meter, does not smoke, no blow by out of the crankcase vent, the oil always looks brand new, but it is getting harder and harder to start (have to use ether if it is under 50 now) and seems to run on between 2 and 4 cylinders and you always have to feather the throttle to keep it running. We put a tune up kit in it that did not make any difference (plugs, wires, cap and rotor, and a new coil) and now I am scratching my head. Anyone have any suggestions on what to look for before I break down and call out a mobile forklift mechanic/butcher (the last couple of times I have used one they seem to break two things for every one they fix)?
