jfon101231
- Jun 5, 2017
Hi all, have lurked on the forum a while but now have a question I was hoping I could get some insight on.
I have a skidsteer with a set of quick attach 48" forks on it. I often use the machine to lift things by scooping up with one piece of metal on top of the forks and the rest of the weight hanging down. The issue/concern I have with that is items can slide in and out on the forks based on how the forks are angled, sometimes sticking and then moving quickly. This is more difficult at higher boom heights where I can't easily tell whether forks are level. I don't want the loads to crash towards the machine and damage something (or too far/fast the other way and fall off the forks). Are there any suggestions? I can only thing of 3 ideas:
1) There are some companies out there that make non-slip "pads" for the forks. Downside is I do need them to be able to slide SOME, because that is how I can control how far away from the machine the load is for placing it into pickup bed etc, and seems like those might increase the stickiness too much and make it even less predictable?
2) I could get a D-ring welded onto the carriage. With a chain etc, this would limit travel outwards only.
3) I could get someone to drill or burn a few holes in the forks and mount some sort of "blocking" to limit movement. This would not decrease the speed it might slide in or out, but at least prevent it from going off the end or coming too close to the machine and damaging the load (or machine)
Welcome thoughts on those choices or any other options I haven't thought of!
