Was the coolant pump the problem? I just got this 217 Thermal Trip alarm...troubleshooting now.
UPDATE: It IS the coolant pump. I looked up the alarm code; it showed QF11 was tripping; cross referenced to the electrical manual and found the coolant pump.
thermal trip is mazak speak for a tripped motor overload
it means a motor is jamed or burned up
the "thermal" part is refering to a thermal overload seeing a higher than normal current draw which is sensed by the temp in overload portion of the motor starter
