640T Lathe Alarm 26 Illegal parameter
Jerod
Sep 10, 2007
Rochester, NY
Guys, I have alarm 26 illegal parameter on my 640T lathe what causes this and how do I reload parameters if necessary? It looks like the battery died over the weekend so I am assuming this is the cause of the parameters being lost. I do have a backup floppy disk but I am not sure which files contain the parameters I need to copy over if that is how you do it.
In order to see what you have on a floppy disk you need a CMT Mazak micro disk reader, looks like a small toaster.
Once you insert the floppy in the reader you will see 1 thru 2 or 1 thru 6 sections depending how it was originally formatted.
You will need to call up each section and select "Contents" to see what is in each section.
It will clearly display programs or parameters.
I am assuming you have a CMT or Mazak Micro Disk Reader, if you don't then you have a problem.
