I've found my notes on the FR-SE drive I worked on. I wish I had written more down. It's not mine so I can't pull it apart and take pictures so you'll have to go with my description. Replacing some parts will require the proper tools and a bit of expertise. It's not rocket science but don't try this unless you've some experience with PCB repair. You'll need a soldering iron, solder and a solder sucker (Soldapullit) in addition to pliers, sidecutters, screwdrivers, etc. A good DMM is also handy.
1.) +5V instability: all the DC power for the various DC voltages comes from the Power supply module through pin and leaf connectors. These are tin plated and can oxidize or the the leaf spring can get weak if overheated. The MEAU tech I talked to was aware of the problem and performs a similar repair if needed.
I pulled the PCB stack and power supply out of the drive and did the work on the bench. The two boards connect with each other by flexible cables and by pin connectors. All +5V has to pass through one connector pin. I made up a couple of jumpers with ring terminals on one end, one red and one black. The wires were 22 gauge and about 3" long. I soldered the free end of the jumpers to the connector pins on the board that doesn't have the two screw terminals in the upper left corner. The ring terminals will go under these screw terminals when the boards are put back together. The red wire connected to +5V on both boards while the black wire connected to GND on both boards.
There's about a dozen screws holding the boards to the frame. I think some were under the power supply cover. Separate the PCB from the power supply by lifting it up. The pins will slide out the the connectors. I used contact cleaner and cotton swabs on the pins to clean off any oxidation before putting things back together.
2.) flakey capacitors: the MEAU tech confirmed some internet lore that the 100 uF and 220 uF capacitors in the driver stage can degrade. Some of the capacitors on this board had already been replaced. These are in the area of the board that has the twelve hybrid modules (black or brown gizmos about 1 by 2 by 1/2"). The capacitors in question are to the left of these modules. I have a DMM that can measure the capacitance in place. At least one of each type on this board was bad. I pretty much replaced them all with parts of the same value and with a higher voltage, something like 25 V. I recall that MEAU used 16 V parts which is close to the 14 or so volts on the parts when operating. I got the replacements either from my personal collection or a local industrial supplier. Digikey(.com) is good supplier and can get replacements to you the next day. I don't think MEAU used any particularly special parts as they really weren't available at the time. Just pick a good quality replacement (Nichicon, Panasonic) possibly with a higher temperature rating and/or a lower ESR value.
3.) The drive would sometimes have trouble starting or, if it did start, would throw a #12 (regen) fault when decelerating. Going through the adjustment procedure in the manual (available on MEAU's site) made me think the trimpots (the variable resistors on the board) were flakey. I eventually figured out that the current sensor that is mounted on the capacitor bank buss bars in the main chassis was NFG. I pulled the current sensor out, figured out which pin was which and bench tested it. I found that its output had almost nothing to do with its input. You'll have to get the exact part from MEAU as it is calibrated for the HP rating of the drive. Similar sensors are used elsewhere in the drive so if you're having trouble with setting currents, it might be due to the current sensor.
Hope this makes sense. I should be able to clarify or answer questions if need be.
Cheers,
Duane
