Captdave
Titanium
- Sep 24, 2006
- Atlanta, GA
None of the ID tool holders have pipe plugs that can be removed to install push on connectors for plastic tubing to attach to coolant through tools. They do have 2 moveable eyes which some tool blocks are threaded and some are not and the threads appear to be M6x1.0.
There appears to be some type of plug on the back side in line with the eyes on the front but haven't pulled the holder to get a better look. If that is the case, then I should be able to drill into the galley way on the side of the holder and tap for a 1/8" NPT fitting.
How have you solved this problem?
[/IMG]
