Results 1 to 4 of 4
    SCP castings is offline Junior Member
    May 2006
    Jonesboro, AR
    Post
    We just got a M-630 - 6 Pallet and we got and Error 365 "ATC shifter was broken"
    but it is still broken and not in the books.
    any ideas?
    wippin' boy is offline Diamond
    Sep 2005
    il.
    5,058
    Post
    847-885-8311
    machtool is offline Titanium
    Jun 2004
    Melbourne Australia
    2,793
    Post
    Long shots.
    Typical Japanese – English translation.
    The mention of pallets, threw me for a moment. Normally expect for pallet changer errors, if you have just installed this. ATC – shifter. They would be good on that. ATC = Auto Tool Change. Try and work out what they might call the shifter in the Tool Changer. A swing arm or something. Some thing that’s not parked at end of stroke, or on its switch. Or has drifted in transport, or at the wrong end of its function.
    You said you just got this machine. So your still in commissioning? Was any of the tool changer disconnected, maybe a problem there, just with a mistake, and not getting the correct I/O. – Phil.
    E-Stop is offline Cast Iron
    May 2002
    Ohio
    437
    Post
    The 'ATC SHIFTER' is the arm that moves between the tool magazine and the tool change position. In manual mode, if you press the ATC button near the bottom right hand corner of the control, the sodt-keys should allow you to manipulate the shifter arm, driving it between 'spindle side' and 'magazine side'.
