Results 1 to 9 of 9
    KBW
    KBW is offline Cast Iron
    Jan 2004
    Alabama
    372
    Post
    Could someone give me some pointers on sending a program from the floppy into a Mazak 640M Nexus control.
    Not looking for directory-send type info, but how to have info on disk correct.
    Currently have post in a directory ie..folder, can open it, select post number then, getting Designated Date Not Found Error.
    Thanks.
    psychomill is offline Titanium
    Mar 2005
    Silicon Valley, California... + other states & several countries on 3 continents
    2,100
    Post
    2 ways.....
    You can open up windows explorer on the control and "drag and drop" into the machine programs folder... or...
    when using the I/O, press "contents FD" and it should see the program on the disk. Select it then start. You may have to create a "directory" on the disk in order to do this. If so, then create a folder on the disk in which the program is under. Then press "directory select" and download the program.
    jero100's Avatar
    jero100 is offline Cast Iron
    Oct 2004
    Southeastern USA
    311
    Post
    and it has .eia extension.
    Mar 2005
    2,100
    Post
    ..... and use the program number for the file name and not text. For example: 1657.eia
    If you move files through windows, the extension and name doesn't mattter. You can change it once its in the control or on the floppy on the control. The file name/extesion will matter though when you try to bring it up on the monitor.
    jero100's Avatar
    Oct 2004
    Southeastern USA
    311
    Post
    Mazak needs to replace the A drive with a USB port!
    Mar 2005
    2,100
    Post
    Or you could just use an IC memory card.... or plug in the ethernet.
    jero100's Avatar
    Oct 2004
    Southeastern USA
    311
    Post
    True.
    But honestly, who uses floppy drives anymore?
    It's hard to find a PC with one.
    Mar 2005
    2,100
    Post
    Got that right. You can still buy just about any PC with a floppy though.... funny thing though... its now an "option" to have it installed. :rolleyes:
    I'm getting old......
    KBW
    Jan 2004
    Alabama
    372
    Post
    Well, I will be untill our wireless DNC from eNetDNC is installed.
    But hey, established communication with the Mazak.
    Created the directory on the floppy, saved eia program to floppy, had to change program name ex. 0303 to just 303 then it took it no problem. I had used a zero in front of the program number.
    Thanks for the help.
