Captdave
Titanium
- Sep 24, 2006
- Atlanta, GA
Just arrived in Bahrain and decided to check online on the status of the drive repair.
Drive was received on 3/19 and the only thing it shows so far is work in progress on the PCB SF-BS, not sure which one that is. The card with visible damage was the SR-CA card, but maybe that hasn't been addressed yet.
The quote for repair I received has gone up a couple of hundred due to it being a -KP drive, which now is $3010.00. If it goes back in without any further problems then I'm happy to pay it to get the machine back in service.
Decided to throw some of the material we had waiting to run on the Mazak onto the Hurco just to get some of them done since I thought I would be leaving on this trip sooner then I did, and was a great chance to give that 1" ripper mill I've been itching to try out.
Using 2 vises with soft jaws we started with the 6"x1.2" slugs, center bore finishes to 3.125". Ran the ripper at 6,000 RPM, 150IPM .175" DOC 65% step over and 5* ramp, cycle time was 4+05 compared to 1+45 on the Mazak, but was still better then I thought it would be. The 4-3/4"x1.5"x2" bore parts took a little less time since the the bore is smaller had to lighten up a bit cutting the bore to keep from re-cutting chips.
BTW, I was surprised that it took longer to pre-drill a 1" hole then to just ramp into the part, I'm sure most of the time was ate up by the extra tool change
That ripper mill is one awesome tool
The kid will be busy shoveling chips this week!
