Fusion 640M- ok control ? How to heck run times ?
Results 1 to 12 of 12
    Dec 2000
    Coastal Dogpatch, SC, USA
    50,669
    2399
    5256
    Default Fusion 640M- ok control ? How to heck run times ?
    2001 vintage if it matters...bugs worked out by then or was that the beginning ?
    Sep 2013
    N IRELAND
    234
    17
    110
    On the lathe control you can check cycle times in the mazatrol programming by pressing program complete then tool path and check continue, this gives you the estimated cutting time after your programs done. If you hit solid it puts it in 3d. You can also get times when the machines running press the left soft key when the machines in auto and press trace this will show you what the machines doing in real time. Also a great feature is single process and vfc
    Dec 2000
    50,669
    2399
    5256
    Quote Originally Posted by IeliteENGINEER View Post
    I mean total run time...since the machine was new and ran first part to today.
    Sep 2013
    N IRELAND
    234
    17
    110
    I think you can do it using the machine button above the auto button, il check it Out tomorrow when I'm out and get Back if no one else has .
    Dec 2012
    Se Ma USA
    1,266
    97
    709
    This is for Mazatrol programs. Right function key until TRACE shows up. Push TRACE while program is running and it will show tool paths in real time. It will also show PART SHAPE if you push that button. When the part is complete it will show the actual time the machine ran until done. Did you drink the Mazatrol Kool Aide? Not so bad at all.
    Jan 2013
    Plainfield, Indiana, USA
    1,494
    1107
    756
    One of the soft keys is labeled 'Diagnostics' . . . explore here and you can find total cutting time and total on time.
  7. Likes Milacron liked this post
    Dec 2012
    Se Ma USA
    1,266
    97
    709
    Quote Originally Posted by Red James View Post
    I misread the original question. The Fusion control was the first Mazak control with a PC front end. It still has some legacy crap in it too. There is a battery in the control that keeps parameters and a lot of other stuff in memory. Maintenance and run time may be stored in the same volatile memory. Battery goes dead and that stuff gets lost.
    It is like the MR J2 battery and needs to be replaced hot, while machine is under power. Total pain in the butt when it goes dead. I had to open up the control and connect a keyboard when mine went dead. Way too much typing on that funky keypad to correct everything. Took many hours to get 48 tool chain magazine back up.
  9. Likes Zahnrad Kopf liked this post
  10. #8
    Apr 2006
    Westside of America.
    3,289
    669
    880
    Diagnos soft key, then use the mouse to go up to "Window" then "Accumulated time".
    Those timers are meaningless though. They can be reset, they roll over on their own, etc.
    For the more accurate, "hidden" timers, go to Diagnos>Version>Servo Monitor, and then page down a few times until you see a row titled "work time".
    Every used dealer who's ever sent me a quote on a very rough looking, 10-15 year old machine, loves to include a picture of the "accumulated time". Seemingly always showing only 3,000 hours. When I tell them that timer is bullshit, and ask for a picture of the servo monitor page - suddenly the correspondence stops. LOL
  11. #9
    Dec 2000
    50,669
    2399
    5256
    Quote Originally Posted by Joe788 View Post
    Few years later looking at another pristine Mazak with Fusion 640 control and surprised the servo monitor time is 27,000 hours ! Any chance this is the time the servos are energized or is it sure enough the time the servo are rotating (i.e. "doing work" ) ? And if it is the time the servos are powered up only are they powered anytime the control is "on" or not ?
    (all other hours are zero, indicating it must have lost parameters recently or purposely reset by dealer....but machine is very clean w/original paint spindle and axis sound good, and therefore seems more like 3,000 hour machine.... so this 27,000 hour figure is surprising indeed)
  12. #10
    Jan 2012
    indiana, usa
    116
    22
    Our Fusion Integrex is as follows:
    Diagnos>Version>Servo monitor>page down 3 times then you will see work time on each axis
    Diagnos>Version>Spindle monitor>page down 1 time then you see work time on each spindle
  13. Likes Zahnrad Kopf liked this post
  14. #11
    Feb 2012
    Georgia
    86
    17
    11
    Quote Originally Posted by Milacron View Post
    .. old thread I know, but needed some facts added. This thread came up while I was hunting for the same answer.
    Mitsubishi 500M manual states (verbatim)
    WORK TIME - The accumulated time of ready-on is display.
    So I take that to mean the Servo is energized.
  15. #12
    Oct 2005
    NORWAY
    815
    283
    165
    27.000 hours doesn't seem far fetched considering the salesman over here brags about a Mazak lathe that has done 200.000 hours in auto-cut.
