Results 1 to 4 of 4
    mthomure is offline Cast Iron
    Feb 2007
    Joplin, Missouri
    256
    Default Good source for a servo motor for QT8
    Guys I am in need of an X axis motor for my QT8. Anyone know of a good low cost supplier?
    Thanks ahead of time.
    Michael
    Pipes is offline Cast Iron
    Feb 2007
    Rhode Island, USA
    301
    Default Motor sources
    First call Mitsubishi (if that is the brand in your QT8) to get pricing on replacement and/or repair. With that pricing in hand scan eBay for the model you need keeping in mind what you find may be used (sometimes new you never know) then check out repair pricing from a reputable servo repair outfit. I highly recommend these guys:
    Servo Motor Repair - Kollmorgen, Yaskawa, Siemens, Fanuc and more!
    I work with Servotech all the time, they are a first rate operation. They may not be the cheapest but their process and quality is exceptional. Do not be fooled by folks that say they can repair for less, I've seen the work of some pretty shody outfits.
    wippin' boy is offline Diamond
    Sep 2005
    il.
    5,058
    Driesilker elec
    factory rebuilds
    630.469.7510
    landm1's Avatar
    landm1 is offline Aluminum
    Mar 2008
    Paso Robles, CA
    234
    Hello,
    Tom told me about these guys, they have a good inventory of old Mazak stuff or they will find it for you if you do not rebuild yours.
    LandM-1
    CNC HORIZONTAL MACHINING CENTERS: Mazak FH-4800 HMC
