BACH
- Oct 28, 2005
- Durban South Africa
My old MAZAK M4 with Fanuc 6T control has an intermittent zero return problem. Only on the Z axis when I start up, the Z zero return gives an error message 090. "Distance from start to zero too small or speed too slow". Some weeks I don't have any problem, then for 3 or 4 days the machine won't normally zero return on Z. I jog backwards and forwards, trying to zero from both sides, and then it zero's with no apparent change in procedure . Sometimes it takes 10 minutes of trying, sometimes hours!! There is no interference with the limit switch or the stop dog. I have tried power off and on with P & CANCEL held down. I have moved the stop dog, tried to do a new "origin" point on Z, tried a g28 return in MDI. I have a really nice big job on the machine and have lost 1 1/2 days now (of the last 3 days) not being able to zero. Today for the first time the Z zero return refused while the machine was running, ie without a power down in between. I am at my wit's end.
My shut down procedure is simply, move off X & Z zero position, press in E Stop button, power off switch on control box, then power off main switch.
I hope there is a way to sort this out. My best source of information locally is talking about replacing bubble memory at R20K to R30K cost. I simply cannot afford to pay that now, and he doesn't sound confident that it will solve the problem.
Any help will be GREATLY appreciated.
PS Please remember that I am a novice machinist and even more novice on CNC.
Regards
Bach
Regards
Bach
